1.0.0-alpha11: Lower audio latency on Android
:warning: Alpha warning
  • Assume that you’ll have to redo all your settings when upgrading from this version
    • e.g.: Going from 1.0.0-alpha01 to [1.0.0-alpha02 or 1.0.0-beta01 or 1.0.0] will result in config loss
  • There could be connection issues when connecting with different versions
  • Expect some bugs
Downloads
These aren’t available on the app stores or the website
:warning: Android and Desktop: This version is compatible with 0.x.x but not with versions prior to 1.0.0-alpha08
In order to connect
All devices need to be on the same alpha version
iOS
:warning: iOS: You need to connect to devices that also use 1.x.x. e.g: Connecting to a PC running 0.x.x won’t work.
  1. Install Apple’s TestFlight
  2. Then AudioRelay via TestFlight
Android
macOS
Linux
1.0.0-alpha11 (2026-08-09)
  • (Early access fix) Fixed the app crashing when clicking cancel on the new connection screen
iOS
  • Fixed the app crashing on iOS < 26
1.0.0-alpha10 (2026-08-08)
  • (Early access fix) Fixed not being able to confirm a connection from a small phone
  • (Early access fix) Reduced CPU consumption while idle
Android
  • Use AAudio as the default audio system instead of OpenSL
  • (Early access fix) Fixed a bug where the OpenSL implementation in previous alphas had a higher latency than in the 0.x.x version. (Audio effects – which increase latency – were always enabled regardless of your selection in settings.)
  • To reduce the number of steps to start media capture, the permission will only show the “Share entire screen” option instead of the “Share one app” first. This can be changed in the app’s settings. (Reported here)
  • (Early access fix) The app will prompt you to accept the notifications permission (Reported here)
  • (Early access fix) Fixed Audio media capture options appearing on Android < 10.
macOS
  • (Early access fix) Changing an audio device’s sample rate lead to audio no longer being captured (Reported here)
  • Moved audio capture to in-process instead of out-of-process
  • Signed all installed dlls (Should help with anti-cheat software complaining about AudioRelay for example)
  • (Early access fix) Fixed the app continuing to run for a few minutes after you closed it down
iOS
  • Fixed a bug where you had to restart the app in order to accept new connections
Previous versions
1.0.0-alpha09: Fixed crashes
1.0.0-alpha08: Fixes, better transition from 0.x.x
1.0.0-alpha07: Early access fixes, UI update
1.0.0-alpha06: Fixed crashes
1.0.0-alpha05: Early access fixes
1.0.0-alpha04: Early access fixes
1.0.0-alpha03: First iOS version
1.0.0-alpha01: Listen from multiple devices, require connection approval, audio settings on desktop, premium on desktop, linux ARM
Known issues
General
  • The app crashes when clicking cancel on the new connection screen
  • The translations aren’t up-to-date.
  • The docs aren’t up-to-date.
iOS
  • The app crashes on iOS < 26
  • Missing device-wide audio capture
  • Missing the equivalent to Android’s playback notifications
Limitations
  • You can’t have multiple audio streams that send audio to AudioRelay’s virtual mic
Notes
  • Sharing Android’s audio won’t work for every app; check the compatibility here
  • Prices are increasing for the 1.0.0 release. For the early bird price, purchase premium from the 0.x.x version or use the coupon EARLYACCESS2025 on the web for the monthly or lifetime purchases.
  • The main site doesn’t link to these pages for now:
Feedback
Hello this isnt a real bug report but the connection between iphone and debian 13 is disconnecting after turning my screen of on my iphone. Both devices use the same alpha version. After turning screen on the connection is there in few ms. Thanks
Hi, I couldn’t find a way to trigger the issue on my end, even when enabling Low power mode.
Getting more info will probably help to narrow it down:
What iPhone model and iOS version do you have?
Does it happen immediately after you turn off the screen?
Does it also disconnect when switching to another app?
If you used previous versions, did it work correctly then?
Would you mind sending the logs here or by private message? It’s in Settings → Help → Logs.
Hi, i have minor issue with audiorelay, and i already tried with alpha11 too… and this stills occurs, i don’t know if it’s possible to fix this or not, anyway, the speaker or mic only function is fantastic thx you very much.
details on said issue, dk if this is possible fix from audiorelay or not, might be windows problem, might be android problems
Hi, in this version i have an error, when i try to connect, it connects but it says this “udp not receiving packet”, and it doesnt send mic audio from my Iphone to my PC, and i dont know how to fix it, i have to reinstall the app, give mic permissions again and again everytime i disconnect and want to connect again.
This topic was automatically closed 15 days after the last reply. New replies are no longer allowed.
