Android audio capture compatibility
Requirements for this feature
  • Device with Android 10 or more
  • The target app needs to be recently updated (target API 29)
  • The target app doesn’t opt-out of the feature
    • Some apps will prevent you from capturing their audio
Read more from Google
Here’s a list of some big apps, please reply or edit this wiki if you’d like to add more
Compatibility list
Compatible
Apps that allow their audio to be streamed
Media
  • VLC
  • YouTube
  • YouTube Music
  • Spotify
  • Deezer
  • Twitch
  • Prime Videos
  • Pocket Casts
Browsers
  • Firefox Focus
  • Firefox Beta
  • Samsung Internet Browser
  • Chrome (Started to work on versions shipped after 2026-06)
Games
It should work with most of them
Not compatible ⊖
Apps which can’t have their audio streamed
Media
  • Netflix
  • SoundCloud
Issues
2026-04 - Bug in Android System WebView
Android System WebView is an auto-updated component in Android, which used by apps to display web content. An recent update prevented audio capture from working in all apps that use it. See the official issue tracker for more details.
If you’re using an app which no longer lets its audio being captured, while it worked before, that’s probably why.
A fix has been implemented and will come into future WebView updates.
If you can’t wait for it to be available on the normal channel, you could install the Beta version as described here.
Rebooting the device could be necessary.
Thank you very much! I downloaded Android System WebView Beta, activated it. Finally I can hear sounds from my phone on my PC again
