The Android version is gradually rolling out.
0.26 (2022-10)
All
- UI: Added Arabic, Norwegian and Italian translations
- Thanks for the contributions at https://translations.audiorelay.net!
Android
- Automatically search for servers like on Desktop
- Updated the Premium screen to make it easier to switch to Lifetime
- Fixed a memory leak occurring when enabling Noise suppression. It caused a crash when running after a while (Thanks for the report!)
- Fixed a crash occurring when streaming uncompressed data on a connection getting a lot of packet loss
- Fixed a crash that happened after changing the device’s name
Desktop
- Added (Windows): The app now adds a Virtual Mic and a Virtual Speaker
- Use the virtual speaker to listen to your PC without emitting sound to your real speakers
- The Virtual Mic simplifies the setup as you no longer need to install third party drivers
- Requires at least Windows 10
- Fixed: A rare crash could occur when using AudioRelay with an empty clipboard
- Fixed (Linux, macOS): Fixed a startup crash on older systems
- Misc: Simplified the focus management from a dev perspective. The tabbing behavior has slightly changed
- Misc (Windows): The installer gained an icon and UI refresh
0.25 (A few months ago)
Android
- Remove noise from your mic’s environment (Premium)
- Boost the microphone’s volume
- Enable or disable built-in mic effects
- Continue playing on headphone disconnects (opt-in)
- Fixed a crash occurring on some Huawei devices stuck on Android 5
- Fixed a crash occurring when resuming playback via the notification on Android 12+
Desktop
- UI: The app remembers the window’s position and size between launches
- UI: Resizing the window should be smoother
- Misc: The Player displays a more accurate buffer amount
- Fixed (Linux): Robot sound when playing Android’s mic
Notes
- Sharing Android’s audio won’t work for every app, check the compatibility here
- There’s a soft-limit of 1 hour for connections to a non-premium Android server. You can simply reconnect when you’re reaching the limit.
- Desktop to Desktop could require a paid license in the future
Anonymous feedback
If you’d like to provide feedback without creating an account or sending an email, please fill this form
Downloads
Available on https://audiorelay.net
