Linux: Can't load audio device
The audio device is always loading.
❯ audiorelay
2022-10-13 19:14:53:238 [INFO] Version: 0.26.3, os: Linux, osVersion: 5.15.72-1-MANJARO
2022-10-13 19:14:53:388 [INFO] Initializing locale to en
2022-10-13 19:14:53:408 [INFO] Network addresses: NetworkInfo(broadcastAddresses=[192.168.31.255], localAddresses=[192.168.31.54])
2022-10-13 19:14:53:410 [INFO] Starting the server...
2022-10-13 19:14:53:413 [INFO] Waiting for devices from PortAudio...
2022-10-13 19:14:53:414 [INFO] Status initializing
2022-10-13 19:14:53:416 [INFO] Checking for update...
2022-10-13 19:14:53:618 [INFO] Showing main window...
2022-10-13 19:14:53:640 [INFO] Rendering api: OPENGL
2022-10-13 19:14:57:333 [INFO] Found no update
Could you please run /opt/audiorelay/bin/AudioRelay > ~/Desktop/audiorelay-output.txt 2>&1 and post the content? There should be more info.
Also, what does pactl info return?
i am facing the same issue after updating to v0.26.3 and logs do not have any errors
audiorelay-output.txt :
2022-10-14 15:24:01:539 [INFO] Version: 0.26.3, os: Linux, osVersion: 5.18.19-3-MANJARO
2022-10-14 15:24:02:030 [INFO] Initializing locale to en
2022-10-14 15:24:02:088 [INFO] Network addresses: NetworkInfo(broadcastAddresses=[192.168.50
.255], localAddresses=[192.168.50.88])
2022-10-14 15:24:02:093 [INFO] Starting the server...
2022-10-14 15:24:02:104 [INFO] Waiting for devices from PortAudio...
2022-10-14 15:24:02:118 [INFO] Checking for update...
2022-10-14 15:24:02:118 [INFO] Status initializing
2022-10-14 15:24:02:578 [INFO] Showing main window...
2022-10-14 15:24:02:639 [INFO] Rendering api: OPENGL
2022-10-14 15:24:04:324 [INFO] Found no update
pactl info returns the following :
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 13
Tile Size: 65472
User Name: sw
Host Name: sw-pc
Server Name: pulseaudio
Server Version: 16.1
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: audiorelay-speakers
Default Source: audiorelay-virtual-mic-sink.2
Cookie: 398c:7c56
Thanks for the logs. Did you run the complete command though?
The ‘2>&1’ part is important.
yes brother , i did make sure to redirect both stdout and stderr to the log file , just copy pasted the command
Same issue here, tried reinstalling with no luck.
audiorelay-output.txt:
2022-10-15 13:22:01:370 [INFO] Version: 0.26.3, os: Linux, osVersion: 6.0.1-270-tkg-pds
2022-10-15 13:22:01:782 [INFO] Initializing locale to en
2022-10-15 13:22:01:832 [INFO] Network addresses: NetworkInfo(broadcastAddresses=[192.168.1.255], localAddresses=[192.168.1.40])
2022-10-15 13:22:01:836 [INFO] Starting the server...
2022-10-15 13:22:01:842 [INFO] Waiting for devices from PortAudio...
2022-10-15 13:22:01:847 [INFO] Status initializing
2022-10-15 13:22:01:850 [INFO] Checking for update...
2022-10-15 13:22:02:345 [INFO] Showing main window...
2022-10-15 13:22:02:393 [INFO] Rendering api: OPENGL
2022-10-15 13:22:02:469 [INFO] Found no update
2022-10-15 13:22:26:958 [INFO] Status terminating
2022-10-15 13:22:26:964 [INFO] Stopping the server, reason: shutdown
pactl info:
Is Local: yes
Client Index: 370
Tile Size: 65472
User Name: krypto
Host Name: Main-Root
Server Name: PulseAudio (on PipeWire 0.3.59)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Sink: alsa_output.pci-0000_29_00.1.hdmi-stereo-extra1
Default Source: alsa_output.pci-0000_29_00.1.hdmi-stereo-extra1.monitor
Cookie: 6161:c01c
Same problem
2022-10-16 11:54:14:942 [INFO] Version: 0.26.3, os: Linux, osVersion: 6.0.1-zen2-1-zen
2022-10-16 11:54:17:089 [INFO] Initializing locale to ru
2022-10-16 11:54:17:249 [INFO] Network addresses: NetworkInfo(broadcastAddresses=[10.19.8.255], localAddresses=[10.19.8.51])
2022-10-16 11:54:17:256 [INFO] Starting the server...
2022-10-16 11:54:17:271 [INFO] Waiting for devices from PortAudio...
2022-10-16 11:54:17:365 [INFO] Checking for update...
2022-10-16 11:54:17:408 [INFO] Status initializing
2022-10-16 11:54:19:123 [INFO] Found no update
2022-10-16 11:54:20:400 [INFO] Showing main window...
2022-10-16 11:54:20:477 [INFO] Rendering api: OPENGL
2022-10-16 11:54:30:945 [INFO] Status terminating
2022-10-16 11:54:30:947 [INFO] Stopping the server, reason: shutdown
pactl info:
Is Local: yes
Client Index: 26
Tile Size: 65472
User Name: roman7662
Host Name roman555555
Default Source: alsa_input.pci-0000_00_1b.0.analog-stereo
Cookie: 18ba:07a8
maybe it’s problem only on arch
/etc/pulse/
default.pa
#!/usr/bin/pulseaudio -nF
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
### Allow including a default.pa.d directory, which if present, can be used
### for additional configuration snippets.
### Note that those snippet files must have a .pa file extension, not .conf
.nofail
.include /etc/pulse/default.pa.d
client.conf
# it under the terms of the GNU Lesser General Public License as published by
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## more information. Default values are commented out.  Use either ; or # for
## commenting.
; default-sink =
; default-source =
; default-server =
#; default-server = roman
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; auto-connect-localhost = no
; auto-connect-display = no
system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
### Allow including a system.pa.d directory, which if present, can be used
.nofail
.include /etc/pulse/system.pa.d
daemon.conf
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
/.config/pulse/
and i use a pasystray
Thanks for all the details. I’m looking into replacing the audio library with something more stable.
Could someone please confirm whether it happens on this older version?
audiorelay-0.25.7.deb
audiorelay-0.25.7.tar.gz
Works as expected. All my audio devices show up, and then some.
2022-10-16 19:28:08,505 main WARN JMX runtime input lookup class is not available because this JRE does not support JMX. JMX lookups will not be available, continuing configuration. Ignoring java.lang.IllegalArgumentException: java.lang.NoClassDefFoundError: Could not initialize class org.apache.logging.log4j.core.lookup.JmxRuntimeInputArgumentsLookup
2022-10-16 19:28:08,634 main WARN JMX runtime input lookup class is not available because this JRE does not support JMX. JMX lookups will not be available, continuing configuration. Ignoring java.lang.NoClassDefFoundError: Could not initialize class org.apache.logging.log4j.core.lookup.JmxRuntimeInputArgumentsLookup
2022-10-16 19:28:08,635 main WARN JMX runtime input lookup class is not available because this JRE does not support JMX. JMX lookups will not be available, continuing configuration. Ignoring java.lang.NoClassDefFoundError: Could not initialize class org.apache.logging.log4j.core.lookup.JmxRuntimeInputArgumentsLookup
2022-10-16 19:28:08,652 main ERROR Could not reconfigure JMX java.lang.NoClassDefFoundError: javax/management/InstanceNotFoundException
	at org.apache.logging.log4j.core.LoggerContext.setConfiguration(LoggerContext.java:637)
	at org.apache.logging.log4j.core.LoggerContext.start(LoggerContext.java:302)
	at org.apache.logging.log4j.core.impl.Log4jContextFactory.getContext(Log4jContextFactory.java:209)
	at org.apache.logging.log4j.core.config.Configurator.initialize(Configurator.java:243)
	at org.apache.logging.log4j.core.config.Configurator.initialize(Configurator.java:219)
	at NZ.a(SourceFile:70)
	at ue.a(SourceFile:34)
	at com.azefsw.audioconnect.desktop.app.MainKt.main(SourceFile:15)
Caused by: java.lang.ClassNotFoundException: javax.management.InstanceNotFoundException
	at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(Unknown Source)
	at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(Unknown Source)
	at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
	... 8 more
2022-10-16 19:28:08,657 INFO Version: 0.25.7, os: Linux, osVersion: 6.0.1-270-tkg-pds
2022-10-16 19:28:08,961 INFO Initializing locale to en
2022-10-16 19:28:08,999 INFO Network addresses: NetworkInfo(broadcastAddresses=[192.168.1.255], localAddresses=[192.168.1.40])
2022-10-16 19:28:09,004 INFO Starting the server...
2022-10-16 19:28:09,009 INFO Waiting for devices from PortAudio...
2022-10-16 19:28:09,015 INFO Status initializing
2022-10-16 19:28:09,016 INFO Portaudio version: PortAudio V19.7.0-devel, revision unknown
2022-10-16 19:28:09,020 INFO Checking for update...
ALSA lib pcm_dsnoop.c:566:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm_dmix.c:999:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib pcm_a52.c:1001:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib confmisc.c:160:(snd_config_get_card) Invalid field card
ALSA lib pcm_usb_stream.c:482:(_snd_pcm_usb_stream_open) Invalid card 'card'
cannot connect system:capture_1 to AudioRelay.C.41759.2:in_000
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1822
2022-10-16 19:28:09,327 INFO Status initialized
2022-10-16 19:28:09,468 INFO Showing main window...
2022-10-16 19:28:09,822 INFO Found update for 0.26.3
2022-10-16 19:28:24,963 INFO Stopping the server, reason: shutdown
2022-10-16 19:28:24,970 INFO Status terminating
2022-10-16 19:28:24,983 INFO Closing main window...
2022-10-16 19:28:24,987 pool-1-thread-1 ERROR Unable to unregister MBeans java.lang.NoClassDefFoundError: javax/management/InstanceNotFoundException
	at org.apache.logging.log4j.core.LoggerContext.stop(LoggerContext.java:379)
	at org.apache.logging.log4j.core.LoggerContext$1.run(LoggerContext.java:320)
	at org.apache.logging.log4j.core.util.DefaultShutdownCallbackRegistry$RegisteredCancellable.run(DefaultShutdownCallbackRegistry.java:119)
	at org.apache.logging.log4j.core.util.DefaultShutdownCallbackRegistry.run(DefaultShutdownCallbackRegistry.java:78)
	at java.base/java.lang.Thread.run(Unknown Source)
	... 5 more
This gets added everytime I press the refresh button on the devices in 0.25.7 (refresh button is greyed out in 0.26.3):
2022-10-16 19:25:27,500 INFO Status initializing
2022-10-16 19:25:27,502 INFO Portaudio version: PortAudio V19.7.0-devel, revision unknown
cannot connect system:capture_1 to AudioRelay.C.39465.2:in_000
2022-10-16 19:25:27,788 INFO Status initialized
I’m also getting really high CPU usage (20-30% on Ryzen 1700) when 0.26.3 is open and on the server or the player tab. The settings tab seems to drop usage back to 0% (0.25.7 barely had any CPU usage most of the time.)
@here, your issues should be fixed in 0.27.
Please try it from
@KryptoSynth Let me know how’s CPU usage there
thanks for the update , my old issue was resolved when i updated after a month , it was related to java-openjdk i think . But cpu usage was still high . I will try this update and will let you know if there is any issue
Audiorelay detects my devices properly now and CPU Usage is back to normal. Thanks!
Here’s the latest log file:
2023-03-18 13:07:58:613 [INFO] Version: 0.27.3, os: Linux, osVersion: 6.2.7-273-tkg-bmq
2023-03-18 13:07:58:983 [INFO] Initializing locale to en
2023-03-18 13:07:59:042 [INFO] Network addresses: NetworkInfo(broadcastAddresses=[192.168.1.255], localAddresses=[192.168.1.10])
2023-03-18 13:07:59:052 [INFO] Starting the server...
2023-03-18 13:07:59:060 [INFO] Waiting for devices from RtAudio…
2023-03-18 13:07:59:389 [INFO] Showing main window...
2023-03-18 13:07:59:428 [INFO] Checking for update...
2023-03-18 13:07:59:671 [INFO] Rendering api: OPENGL
2023-03-18 13:08:00:196 [INFO] Found no update
2023-03-18 13:08:02:726 [INFO] Remote device connected: 192.168.1.37
2023-03-18 13:08:02:740 [INFO] Received client config, clientVersion: 0.26.1, os: ANDROID, osVersion: Android API 33
The reported device's input latency is 0 or unavailable
2023-03-18 13:08:03:269 [INFO] Audio pipeline is emitting values
2023-03-18 13:08:26:940 [INFO] Checking for update...
2023-03-18 13:08:27:211 [INFO] Found no update
2023-03-18 13:08:52:170 [INFO] Stopping the server, reason: shutdown
2023-03-18 13:08:52:172 [INFO] Remote device disconnected: 192.168.1.37...
