Error 0x8007000b when connecting
PHONE DONT CONECT EROR 0X8007000B, Please help me someone!!!
Are you using a 32-bit version of Windows?
Click here to learn how to check.
If you’re on 64-bit, please try this version
If you’re on 32-bit
  • Try to reinstall the application from https://audiorelay.net
  • Or get premium and disable the compression through the app’s settings
