Crash when opening MacOS
Hello, when I open the app it crashes this are the details.
Details
Hello, it seems that there’s an issue when running on High Sierra. I could reproduce the crash through a cloud machine.
Right now you could start the application by running this command:
export SKIKO_RENDER_API=SOFTWARE && open /Applications/AudioRelay.app
We’ll have to wait for a fix from this library.
I also have this problem on high sierra. Maybe send a log report?
actual error:
*** Error ***: Skia's Metal backend no longer supports this OS version.
So yeah. Doesn’t work.
edit: https://skia-review.googlesource.com/c/skia/+/401816/
Hi @Yury, @IVAN_Quesada_Temprad
This version should work on your machines
It automatically switches to a software renderer when it detects an older macOS version.
Please let me know if there’s still an issue.
