V0.26.3 - Child process exited with code 1
Hi!
App (0.26.3) downloaded and installed on freshly updated Win10Pro64bit. Crashes with “Child process exited with code 1” message in little modal then exits.
Toshiba Portege Z30 (i5-4010u)
https://pastebin.pl/view/c7878bef - this is dump log created with
.\runtime\bin\java.exe -cp "app/audiorelay.jar" com.azefsw.audioconnect.desktop.app.MainKt > %USERPROFILE%/desktop/output.log 2>&1
Any ideas?
It seems GPU related. As the relevant error message is
  1. Failed Direct3D call. Error: 0x887a0005
Would you mind posting your graphics card setup?
Graphics card: ?
Graphics card driver version: ?
Example:
Intel HD Graphics 530 - driver version 21.20.16.4550
Nvidia GeForce GTX 960M - driver version 27.21.14.6140
What you can try:
Intel(R) HD Graphics 4400
Driver date: 04.11.2020
Driver version: 20.19.15.5171
Aaaaannnnndd…
I tried to update driver using autoupdate tool. It “upgraded” driver to:
Driver date: 27.12.2018
Driver version: 20.19.15.5070
Clearly - OLDER version. And voila! AudioRelay is working!
So, basicly, my problem solved, but strange way. De facto downgrading graphics (!) driver is a solution.
BTW - AR is great! Ability to play sound on output device different than default one is a killer feature for me. I have game sounds in my BT headphones, my wife got YouTube music on 5.1 logitech connected to my desktop ;D
