eu quero conectar via usb mas so aparece o ip de conectar via wifi começou do nada antes eu usava ja o progama e nunca deu erro
I want to connect via usb but the ip to connect via wifi only appears. It started out of nowhere before I already used the program and it never gave an error
Just to be clear
- If you go to Network status via the Windows search bar, do you see a 2 connections?
- In AudioRelay for PC, do you see a single IP address?
Here’s what I get when I enable USB tethering
Network status
AudioRelay
If you see both connections, try to simply set the Network profile of the USB connection to private.
Or click on follow the instructions of the Check firewall button in AudioRelay for PC.
If you only see a single connection, I’m not sure on what to do.
Beside waiting for this feature.
