It works fine when I run them on the same network, my phone can act as server with no issue. However, once I go outdoors and onto a data connection, I can’t figure out how to connect to the phone from the PC.
Using either the IP shown in the app after starting the server, or my “public IP” both fails.
Is there any solution you can think of where connecting is done through authentication instead? For example, when I use Google Remote Desktop, no matter what network I use I can connect both ways, as both devices are logged into the same Google account.
Otherwise, a solution where the app runs on another server on the phone could work, but I don’t know how to achieve this. Thanks!
Please note the model and versions of your devices.
newest android
s25 phone
Desktop:
Win 11 giga pc
