Error: Child process exited with code 1
Application does not start after update to 0.27, shows error “Child process exited with code 1”.
When starting the application, the error appears.
Microsoft Windows [Versión 10.0.19045.2788]
Android 13
Hello @Nekko,
In order to get some info about the crash, could you please follow these instructions?
• Open Command prompt
• Run cd "c:\Program Files (x86)\AudioRelay"
• Run .\runtime\bin\java.exe -XX:ErrorFile="%USERPROFILE%\desktop\audiorelay-crash.log" -cp .\app\audiorelay.jar com.azefsw.audioconnect.desktop.app.MainKt > %USERPROFILE%/desktop/audiorelay-output.log 2>&1
• Upload the audiorelay-crash.log and audiorelay-output.log files that were created in your Desktop
Hi @Asapha ,
The "audiorelay-crash.log" file did not appear. Here I show you “audiorelay-output.log”:
audiorelay-output
Thanks for the logs.
What’s your graphics card?
Switching to software rendering will probably help.
Please try these instructions.
Thanks u so much!
Now it works well!! :smile:
when running this second command then shown “The system cannot find the path specified.”
or just go to C:\Program Files (x86)\AudioRelay\app\AudioRelay.cfg
and add this line at the end of the file
java-options=-Dskiko.renderApi=SOFTWARE
then save it, preferably using notepad++ in admin mode
Where am I uploading it to please?
this work u are the goat, man.
hello, so when i run this command this shows up
am i doing anything wrong?
