Cant open port
It cant open port 59100, and the fact that you use fixed ports instead of dynamic is pissing me off. it isnt reserved, it isnt in use, it just cant open it for whatever reason. next update just add dynamic or custom ports cuz this is dumb and i literally have to install an alternative version of your app to get my audio working again.
it fixed after pc restart, but talk about things that shouldnt even begin to be an issue
Do you mean that it worked after installing this one? Or another app? Since you said that you needed to restart in the end, I’m a bit confused.
Yes, that’s quite strange.
I’ve opened this topic to try to find the root cause, please post there if the issue comes back
