Can't connect two windwos PCs
Can’t connect two windwos PCs, when win11 pc player is connected to win10 server, sometimes this error will appear, sometimes not.
But if win10 pc is used as player to connect to win11 server, it can connect normally, this error never occurs.
2024-08-02 21:49:21:685 [INFO] Remotely connecting to 192.168.0.92...
2024-08-02 21:49:21:686 [ERROR] Stopping the player: java.net.BindException: Address already in use: bind
	at java.base/sun.nio.ch.Net.bind0(Native Method)
	at java.base/sun.nio.ch.Net.bind(Unknown Source)
	at java.base/sun.nio.ch.DatagramChannelImpl.bindInternal(Unknown Source)
	at java.base/sun.nio.ch.DatagramChannelImpl.bind(Unknown Source)
	at java.base/sun.nio.ch.DatagramSocketAdaptor.bind(Unknown Source)
	at java.base/java.net.DatagramSocket.bind(Unknown Source)
	at kg.a(SourceFile:57)
	at eg.a(SourceFile:2)
	at t01.b(SourceFile:5)
	at r01.a(SourceFile:1)
	at A01.a(SourceFile:11)
	at Ii0.b(SourceFile:9)
	at ek0.b(SourceFile:1)
	at nj0.b(SourceFile:18)
	at pj0.run(SourceFile:68)
	at MG0.invoke(SourceFile:1)
	at bT.invokeSuspend(SourceFile:6)
	at bT.invoke(SourceFile:1)
	at ki1.a(SourceFile:136)
	at a0.a(SourceFile:41)
	at OG0.a(SourceFile:139)
	at NG0.invoke(SourceFile:2)
	at Hu.invokeSuspend(SourceFile:12)
	at jUr4.resumeWith(SourceFile:5)
	at Eu.run(SourceFile:163)
	at Q40.run(SourceFile:4)
	at Ba1.run(SourceFile:1)
	at Yj.run(SourceFile:19)
2024-08-02 21:49:21:686 [INFO] Stopping the player, reason: error
I tried the method mentioned in this post, but it didn’t work.
Knowing how to reproduce the bug will help.
Let us know which devices you used, it’ll probably help.
Windows 11
Android 10
Could you please let me know how to connect server and player between two PCs?
I want to share microphone between 2 PCs
Thank you
