Blank screen on startup
Android 10
Tecno pop 4
AudioRelay 0.24.6
Desktop
COMPUTER HARDWARE (DIY), Windows 10
AudioRelay 0.24.2
You haven’t described your issue.
Would you mind posting your graphics card setup?
It could help fix the root cause.
Graphics card: ?
Graphics card driver version: ?
Example:
Intel HD Graphics 530 - driver version 21.20.16.4550
Nvidia GeForce GTX 960M - driver version 27.21.14.6140
Following these instructions should fix the issue though
Hello, I had the same issue and this solution fixed it.
Thanks a lot!
Great!
I only have GT730
Thanks for the details. Does the app works for you now? (after following the instructions above)
I followed the above instructions and it is working now, thanks.
system: GeForce GT 635M , windows 10
is there any way the mic input from the android app can be used as a virtual input device in windows apps, for eg in skype, so that we can use android phone as mic input.
Thanks for the report.
Yes you can use your phone as a mic, please try these instructions:
Worked for me! Thanks.
