Hi, I have installed Audio Relay (0.24.9) on a Samsung SM-P200 and enabled the server to stream apps to my Windows 10 PC (Audio Relay 0.24.7)
With youtube, it works fine. but when trying to stream Netflix content, I get no sound on PC.
Tablet:
Android 11
Samsung Galaxy Tab A with S Pen SM-P200
AudioRelay 0.24.9
Asus, Windows 10 21H2
AudioRelay 0.24.7
Asapha
May 21, 2022, 12:00pm
2
Unfortunately, the feature won’t work for every apps.
If an app makes copyrighted material available, there’s a high chance that they’ll prevent audio recording from working.
You can check some examples here:
Requirements for this feature
Device with Android 10 or more
The target app needs to be recently updated (target API 29)
The target app doesn’t opt-out of the feature
Some apps will prevent you from capturing their audio, it’ll mostly be apps playing copyrighted material.
Read more from Google
Here’s a list of some big apps, please reply or edit this wiki if you’d like to add more
Compatibility list
Compatible
Apps that allow their audio to be streamed
Media
VLC
YouTube
YouTub…
I have ideas for a couple new features. Where can I post?
Asapha
May 23, 2022, 12:21pm
4
You can post them in this category
Just make sure that they haven’t been posted yet
