USB tethering keep disconnect
As topic, logs as below.
2026-09-01 12:05:01.072 [INF] Detected audio devices changes
2026-09-01 14:32:26.382 [INF] Changing process audiorelay-backend priority from Normal to High
2026-09-01 14:32:26.412 [INF] Changing process AudioRelay priority from Normal to High
2026-09-01 14:32:26.421 [INF] Starting a capture...
2026-09-01 14:32:26.817 [INF] Capture using the suggested format 16 bit PCM: 48kHz 2 channels
2026-09-01 14:32:35.475 [INF] Stopping the capture...
2026-09-01 14:32:35.481 [INF] Changing process audiorelay-backend priority from High to Normal
2026-09-01 14:32:35.519 [INF] Changing process AudioRelay priority from High to Normal
2026-09-01 14:35:06.947 [INF] Starting a capture...
2026-09-01 14:35:06.954 [INF] Changing process audiorelay-backend priority from Normal to High
2026-09-01 14:35:06.985 [INF] Changing process AudioRelay priority from Normal to High
2026-09-01 14:35:06.997 [INF] Capture using the suggested format 16 bit PCM: 48kHz 2 channels
2026-09-01 14:36:43.055 [INF] Stopping the capture...
2026-09-01 14:36:43.065 [INF] Changing process audiorelay-backend priority from High to Normal
2026-09-01 14:36:43.122 [INF] Changing process AudioRelay priority from High to Normal
2026-09-01 14:38:55.137 [INF] Starting a capture...
2026-09-01 14:38:55.157 [INF] Changing process audiorelay-backend priority from Normal to High
2026-09-01 14:38:55.194 [INF] Changing process AudioRelay priority from Normal to High
2026-09-01 14:38:55.196 [INF] Capture using the suggested format 16 bit PCM: 48kHz 2 channels
2026-09-01 14:40:34.105 [INF] Stopping the capture...
2026-09-01 14:40:34.115 [INF] Changing process audiorelay-backend priority from High to Normal
2026-09-01 14:40:34.164 [INF] Changing process AudioRelay priority from High to Normal
Please note the model and versions of your devices.
Android 16
Oneplus 13
Lenovo Thinkpad T480, Windows 11
