If I remove the USB cable during USB teethering, the connect cannot be restored on plugging it back in.
Connect via USB Teethering
Remove the USB cable
Reconnect the USB cable
The Player is now stuck trying to reconnect. Which won’t happen, because the USB Teethering setting reset back to “no” after removing the cable. And I cannot access those settings, because I am on the player screen.
Either:
- don’t disable USB teethering while a connection is trying to re-establish (ideally)
- stop all USB based connections if USB teethering goes off (since it won’t work anyway)
- give me the ability to re-activate USB teethering, even if it is trying to reconnect (so I can fix the setting)
Windows 10
Android 13
