USB connection on iOS
Hello - I have a MacBook running MacOS 10.13 and an iPhone 8 running iOS 16. The loudspeakers on my MacBook are broken, but my iPhone’s speakers work well, so I thought I might send audio from my iTunes library to my iPhone speakers instead - exactly what AudioRelay is good for!
Or so I thought. I work in a country estate where there is no Wifi at all, but can connect my iPhone to my MacBook via USB. I have seen lots of references to networking AudioRelay between Mac and iPhone via USB, but I suspect this may be about Android phones only…
Anyway, I downloaded the Beta of the iOS version of AudioRelay today and installed BlackHole as well as a virtual microphone, but it seems the phone cannot connect to the Mac. The instructions on the Audio Relay web site show an Android phone offering a list of servers if everything is correctly connected, but all I have on-screen in the iOS version on my iPhone is ‘Found No IP address’. Attempts to connect to my MacBook by its IP address don’t work. Under ‘Devices’ all I see is ''No connected devices yet’.
My question is: CAN I use USB to connect the iPhone to AudioRelay? Or does that only work with an Android phone?
And if it should work… what am I doing wrong? Clearly the iPhone app is not ‘seeing’ the BlackHole output to route it to the phone’s speakers. Can you help?
Many thanks,
Matt Bell
Bury St Edmunds,
Suffolk
England
At the moment, the USB connection on Android works by enabling USB tethering.
You should be able to share your iPhone’s connection to your Mac using USB, as indicated in the section " Connect to a Personal Hotspot with a USB cable" of this page Share your internet connection from your iPhone - Apple Support.
Have you already tried that?
The issue is that your Mac could your phone’s data.
I haven’t personally tested that as I don’t have SIM equipped iOS devices yet.
