USB Audio Quality
I want to know the audio quality.
When I use USB to connect PC, I see network traffic is about 480Kbps in task manager.
When I use Wi-Fi connect PC and choose lossless option, network traffic is about 2~3Mbps.
Which is more quality between USB and Wi-Fi?
Thanks.
AudioRelay makes no distinction between a Wi-Fi or USB connection. The network traffic should be the same.
It’s probably a reporting issue.
If you want to be sure, please go the Performance tab of the Task manager, then search for the Ethernet connection corresponding to the USB tethering. You’ll find it by comparing the IPv4 address with the one displayed in AudioRelay.
There, you should see the correct amount.
