Unable to stream to Android from Linux: console says "Audio pipeline is emitting values" but on the phone there's no audio output at all
Server: Linux 0.27.5
Player: Android 0.26.1
On the phone, there’s no buffer or latency info, not sure what’s going…
Apparently I have multiple IP addresses set on the Wi-Fi interface and AudioRelay was getting confused. Once I changed that everything is working as expected.
Think I have a similar problem ish. Not quite sure what you mean though - what wifi interface are you talking about? Can only see one IP in your screenshot
After disabling my wifi it worked immediately.
Thanks you !
Noting that this sort of “confusion” should no longer happen when 1.0.0 ships (Since 1.0.0-alpha05: Early access fixes)
