Hello there! I’m trying to play audio from my Windows virtual machine on Proxmox, it successfully connected but no audio data is received.
- The firewall is disabled both on the Windows virtual machine and Proxmox.
- I’m connecting to the virtual machine via Ethernet, with traffic route to 192.168.2.2 which is the Proxmox host (then to the virtual machine).
- On windows, connecting AudioRelay to 127.0.0.1 does receive audio data normally. Indicated by the latency display.
Client
MacOS 13.7.6
2025-06-14 12:06:29:545 [INFO] Version: 0.27.5, os: Mac OS X, osVersion: 13.7.6
2025-06-14 12:06:29:987 [INFO] Initializing locale to en
2025-06-14 12:06:30:139 [INFO] Network addresses: NetworkInfo(broadcastAddresses=[192.168.1.255, 192.168.2.255], localAddresses=[172.16.0.2, 192.168.1.208, 192.168.2.1])
2025-06-14 12:06:30:164 [INFO] Starting the server...
2025-06-14 12:06:30:180 [INFO] Waiting for devices from RtAudio…
2025-06-14 12:06:30:398 [INFO] Checking for update...
2025-06-14 12:06:30:967 [INFO] Showing main window...
2025-06-14 12:06:31:030 [INFO] Rendering api: METAL
2025-06-14 12:06:32:032 [INFO] Found no update
2025-06-14 12:07:03:335 [INFO] Remotely connecting to 192.168.10.200...
2025-06-14 12:07:03:436 [INFO] Received server config, server: 0.27.5, os: WINDOWS, osVersion: Windows 10
2025-06-14 12:07:03:516 [INFO] Sentry initialized
2025-06-14 12:07:04:460 [INFO] New audio config...
2025-06-14 12:07:04:463 [INFO] Will resample output from 48000 to 44100
2025-06-14 12:07:08:446 [WARN] UDP socket timed out, the app is not receiving audio data packets
2025-06-14 12:07:13:447 [WARN] UDP socket timed out, the app is not receiving audio data packets
2025-06-14 12:07:18:447 [WARN] UDP socket timed out, the app is not receiving audio data packets
2025-06-14 12:07:23:447 [WARN] UDP socket timed out, the app is not receiving audio data packets
2025-06-14 12:07:28:447 [WARN] UDP socket timed out, the app is not receiving audio data packets
2025-06-14 12:07:33:447 [WARN] UDP socket timed out, the app is not receiving audio data packets
2025-06-14 12:07:38:448 [WARN] UDP socket timed out, the app is not receiving audio data packets
2025-06-14 12:07:43:448 [WARN] UDP socket timed out, the app is not receiving audio data packets
2025-06-14 12:07:48:448 [WARN] UDP socket timed out, the app is not receiving audio data packets
Server
Windows 10
25-06-14 12:07:02:359 [INFO] Remote device connected: 192.168.10.0
2025-06-14 12:07:02:390 [INFO] Received client config, clientVersion: 0.27.5, os: MAC_OS, osVersion: Mac OS X
2025-06-14 12:07:02:397 [INFO] Asking backend to start capture. EventSync: true, ContinuousStream: true, AudioConfig: AudioConfig(sampleRate=48000, bits=16, channels=2), AudioDevice: Remote Audio,
2025-06-14 12:07:02:912 [INFO] Audio pipeline is emitting values
