Hi there,
I’m using AudioRelay on Arch Linux (v0.27.5) and trying to make it accessible over Tailscale, a mesh VPN that creates a virtual network interface (tailscale0) with an assigned IPv4 address (e.g., 100.x.x.x).
When launching AudioRelay, I see the following network addresses detected:
Network addresses: NetworkInfo(
broadcastAddresses=[0.0.0.0, 10.42.0.255, 192.168.178.255],
localAddresses=[10.42.0.0, 10.42.0.1, 192.168.178.49]
However, my Tailscale IP (100.89.146.109) is not picked up, even though it’s correctly assigned and reachable from other Tailscale devices.
I suspect the reason is that the tailscale0 interface has these flags:
<POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP>
And no MAC address (link/none), no broadcast, and marked POINTOPOINT. This may cause AudioRelay to ignore it.
I’d like AudioRelay to either:
- Include valid Tailscale IPv4 addresses in its detected interfaces, or
- Provide an option to manually specify a listening address (e.g., via CLI or config file)
But haven’t found any of these in start options…
Thanks!
