Streaming phone audio while sharing screen on Discord
Hi there!
I’ve been using the app to stream my phone’s audio to my computer and that’s working great so far. However, when I try to share my phone screen through Discord at the same time, the audio streaming stop working: the connection stays on but there’s no sound going through anymore… The goal here is to be able to stream both audio and video since Discord doesn’t stream audio on mobile.
Is there something I can do to make that work? Or is it just impossible because of some sort of conflict with the 2 captures going on at the same time?
Android 10
Xiaomi Redmi Note 9 Pro
AudioRelay 0.24.9
Asus, Windows 10
AudioRelay 0.24.7
Hi @Ouronox,
It doesn’t seem possible to have 2 captures at the same time. :frowning:
The system asks AudioRelay to stop capturing when you start Discord’s screen capture.
I see, thanks for the clear answer ^^
Its Android problem not AudioRelay’s Problem
