Stereo audio only in left channel on client (except VoIP quality) – Android-to-Android
Latest app versions on both devices. New trial user.
Setup:
  • Server: Inmo Air 3 (Android 14)
  • Client: Samsung Galaxy S25 Edge (One UI 8, Android 16)
  • Connection: Same Wi-Fi or Inmo on S25 hotspot
  • Output: Bluetooth headphones or built-in speaker on client
Issue:
Audio only plays in left channel when quality is set above VoIP (10 kb/s). Right channel silent. VoIP mode works (both channels, as it’s mono).
Reproduce:
  1. Start server on Inmo
  2. Connect client (S25)
  3. Set quality to non VoIP option.
  4. Play any audio on server
Troubleshooting tried (no change):
  • Client player settings: Switched audio output (OpenSL ES, AudioTrack, etc.)
  • Toggled low latency
  • Adjusted buffer sizes
  • Tested with phone speaker instead of headphones
No errors shown. Happens with any app/audio source on server.
Expected: Full stereo at all qualities.
Thanks for any help.
Could you please try with the latest alpha available at Announcements?
The sound is correctly sent as stereo from a Pixel 8 on my end.
Edit:
Have you tried the reverse just to check? From the S25 to the Inmo? I guess it’s an issue in Inmo’s implementation.
I should add a toggle to force mono on the sender side for cases like these.
