When I receive a call, audiorelay stops, which makes sense. But after the call ends, the audio delay becomes really noticeable. Have to restart the app.
So, I’m assuming that simply reconnecting doesn’t work.
You notice the delay regardless of the buffer value? i.e: it’s at <20ms but it’s still delayed.
Does it happen if you call yourself for a few seconds? I’m trying to find a quick way to reproduce the issue but it doesn’t seem to happen on my end.
What’s your device’s model?
simply reconnecting does not work, no. buffer is low. I have to restart the android app. Buffer size is the same as before and after restart.
