I pay for the android version and right now the MIC feature is really good, i’m asking for you to add an option to connect multiple devices AudioRelay MIC using ip:port, basically instead of using a different app to call, like discord, we can keep all to AudioRelat which is better. (The best thing ever is to keep my bluetooth earbuds from going into call mode and instead use my phone’s MIC, but right now i need a PC to join a call, so i use audiorelay and discord on my PC)
Feature example, both users are using Android phones: user1 turned on the requested option and is now using his MIC while listening to other connected users MIC, user2 uses ip:port of user1 so now user2 will be sending his MIC and listening to user1 MIC (and more users if the feature ends up well). For this they could open the port AudioRelay will be using for this or they could use some vpn. ![]()
Make it a beta or alpha option for testing, and in the future if audiorelay gets the feature to host it’s own servers, this could work too
and may i add one more line: “by controlling the volume, could user1 add music? Not only his MIC? His MIC volume and Music volume being separated of course”
This is a lot to read, but i would love to see the feature live!
