After installing audiorelay for desktop-pc ( ubuntu ) and android smartphon, server is running and connected. Although both devies are in the same wifi, prog on android says - rtrying to connect. How can I connect the smartphon to the server?
According to your other post, you’re using an old version of AudioRelay. Please update it first.
