To avoid incessant switching between 2 wired headphones I’m currently using Audiorelay to stream my PC’s audio to my smartphone (remark: I use the USB cable connection method ONLY to avoid any latency issues).
So far everything works well ! However, once PC audio stream is interrupted by a smartphone app (like youtube) the audio stream coming from my PC isn’t automatically reconnected when I switch off the app. I tried to find an option for this in the settings but without any success.
Is there a way to reconnect the server’s audio stream automatically after stopping the players one ???
Thanks in advance
Best regards.
Alex
On Android, there are temporary interruptions (receiving a call), transient interruptions (navigation instruction from Google Maps) and “permanent” ones (playing a video from YouTube).
AudioRelay already resumes the playback on temporary and transient interruptions… But I don’t think I’d be able to add an option that tells the app to resume playing after a permanent one.
Right now, you can totally disable reacting to audio interruption via the app setting Exclusive audio | Deactivated
