Voglio inviare l’audio dal pc allo smartphone ma non all’uscita audio ma all’ingresso in modo da mandare in streaming dallo smartphone quello che ascolto sul pc esiste qualche soluzione?
Admin edit (DeepL translation):
I want to send the audio from the PC to the smartphone but not to the audio output but to the input so as to stream from the smartphone what I listen on the PC is there any solution?
What’s the end goal? Send the audio as an input to an app on your phone? For example Skype/Discord.
Technically, I don’t think it’s going to be possible.
