The software requires libflac8 and debian 12 uses libflac12
, but even though when I install libflac8, Audiorelay sounds like alien sounds.
Same problem here, but i solved it somehow. So i installed Pulse audio volume control. I would recommend you to install it from synaptic package manager. pkg name = pulseaudio-utils .
(or else use this command for debian/ubuntu => sudo dnf install pavucontrol ).
Then in the app, in recording section select [Monitor of build in audio analog stereo].
PS: if you are facing this (sound coming from pc as well as phone) => just connect earphone to the pc. You are done.
thanks
It works! thank you very much, sir.
bro, how to download libflac8 this package
You can download the .deb file from here:
And then Open a terminal from Downloads folder or cd into Downloads folder
sudo dpkg -i <file_name>.deb
Replace the filename with whatever filename is valid.
After this install AudioRelay and it should work now.
