Not to hear the microphone in my headphones
hello (i use google translate),
I use audio relay as a microphone because I can’t use microphone for random reasons.
I would like to know if it would be possible, not to hear the microphone in my headphones.
Describe the problem here.
Please note the model and versions of your devices.
Android 12
Samsung Galaxy
AudioRelay 1.0.0
Asus, Windows 11
@Jonathan_Jeanson Would you mind describing your exact setup so that I can reproduce the issue?
Are you only sending audio from Android to Windows? Or also sending the audio from the PC to Android?
Is it a Bluetooth or a wired headset? Connected only to your PC?
What audio device(s) have you selected in the app?
etc.
