so, i just installed audio relay on my pc and my phone, but when i connect it, there is notif on my phone "check that your firewall allows udp packets on port 59100
i double checked the router port forward and the firewall, both are open
the funny thing is: services like tailscale make it work.
i came to the conclusion that the app itself fails to create a correct firewall rule or udp socket to send the stuff that needs to send, while allowing things like tailscale to still work
@kleinzz@SuperFurias It should improve in the next version. Would you mind trying the current alpha version? You can find it here Announcements (you need it to install it on both devices for the full effect)
