I downloaded audiorelay for linux ( deb and for android ) , installation was successfull. Server is running but when checking audio device stats says - no sound detected although trying all the possibilities there. Device and pc are in the same
Audo device is set as default
motog For example, if you’re trying to connect a phone to a laptop:
I downloaded the newest version 0.8 for android.
I acted on your advice and the manual and set audio device to AudioRelay Speakers.
But in volume control the set for speakers is plugged out which I can t change.
And still no sound
