No audio
no audio when using audiorelay i have this issue alot and can’t figure out why it’s happening, everything is set up right, can anyone help me fix this issue?
it’s a firewall issue.
  1. Allow AudioRelay’s specific communication ports through the firewall sudo ufw allow 59100:59200/udp sudo ufw allow 59100:59200/tcp
  2. Make sure the firewall is enabled with the new rules active sudo ufw enable # 3. Reload the firewall to apply changes sudo ufw reload
Hi, if you’re still having this issue, I’d suggest to try the latest version from Announcements.
If it’s still there, please post the logs from both devices. It’ll help get a better idea of what’s happening. (Logs available from Settings → Help → Logs)
