No audio, using Phone as a Mic for Linux PC
I have created a permanent virtual audio device following this: Phone as mic for Linux - AudioRelay and I connected successfully however there is no sound on my Linux machine when using the mic
I set the input to Virtual-Mic on Linux-Mint settings.
There is this WARNING in the log file that keeps happening:
[WARN] UDP socket timed out, the app is not receiving audio data packets
and also these errors:
[ERROR] Error on config exchange: java.net.SocketException: Connection reset
[ERROR] Stopping the player: lb0: java.net.SocketException: Connection reset
you can find the full log file in the link below
https://pastebin.pl/view/c198287b
Android 14
Nothing Phone (1)
PC:
Motherboard: Asus prime b450-mk , Linux Mint 21.3
