No audio sent from Linux to Android
There’s no audio on a POCO M3 Pro 5G (running MIUI Global 14.0.6), sent by HP 240 G7 (running Debian Trixie), even though both are connected. There’s data transfer. The audio volume can be controlled on the AudioRelay server.
There’s no further information in the server log (now I’m wondering if there are no log levels to choose from).
2026-10-02 14:59:27:880 [INFO] Checking for update...
2026-10-02 14:59:28:759 [INFO] Found no update
2026-10-02 15:11:26:386 [INFO] Remote device connected: 192.168.1.141
2026-10-02 15:11:26:395 [INFO] Received client config, clientVersion: 0.26.1, os: ANDROID, osVersion: Android API 33
2026-10-02 15:11:26:899 [INFO] Audio pipeline is emitting values
2026-10-02 15:13:04:510 [INFO] Remote device disconnected: 192.168.1.141...
2026-10-02 15:14:40:308 [INFO] Remote device connected: 192.168.1.141
2026-10-02 15:14:40:320 [INFO] Received client config, clientVersion: 0.26.1, os: ANDROID, osVersion: Android API 33
2026-10-02 15:14:40:767 [INFO] Remote device disconnected: 192.168.1.141...
2026-10-02 15:14:43:994 [INFO] Remote device connected: 192.168.1.141
2026-10-02 15:14:44:045 [INFO] Received client config, clientVersion: 0.26.1, os: ANDROID, osVersion: Android API 33
2026-10-02 15:14:44:548 [INFO] Audio pipeline is emitting values
2026-10-02 15:15:35:196 [INFO] Remote device disconnected: 192.168.1.141...
Please note the model and versions of your devices.
POCO M3 Pro 5G
MIUI Global 14.0.6 / Android 13TP1A.220624.014
AudioRelay version 0.26.1
HP 240 G7 Notebook PC
Debian GNU/Linux 13.7 «Trixie»
AudioRelay version 0.27.5
