The microphone volume is really low when I test it on https://online-voice-recorder.com/ on PC and compared it on phone.
Please note the model and versions of your devices.
Android 8
P10 Lite
AudioRelay 0.24.6
PC:
Windows 10
AudioRelay 0.24.3
Conclusion:
- The normal microphone would be the Voice comunication that is the normal microphone volume.
Question is: Why is breaking the received sound?
The sound is fading out and in randomly when no Heatset.
And when with Headset whe sound is really weird, no bass, small fading out-in. You can’t listen to.
Why the echo cancelation works on received sound and not to what mic is sending out. This is really weird and breaks it.
