Initial window is too big on 1080p
On opening the app from the system tray, the window is really long and stretches below the task bar.
And is in a really odd position.
Even if you resize the window, the app does not remember the size of the window and defaults back to the odd size that stretches below the task bar…
Hi @HitFrostbite, I don’t know what causes the weird size but the app will remember its latest size/position on the next update. It should be available in a few days. (version 0.25.x)
What’s your display’s resolution? A screenshot could also help.
Hi @Asapha
My display’s resolution is 1920*1080.
I’ve attached a screenshot of the window as well.
It always opens in this position and size.
Thanks for the screenshot.
I’ve reduced the initial size and it’ll remember your last setup on subsequent launches.
Glad to hear that!
@Asapha
Hi, haven’t received the update yet…
Even after manually checking for the update.
Just wanted to ask where I can get it from?
Sorry it’s not there yet, I found a few things to fix… :slight_smile:
I’ll let you know when it’s available.
ok, will do.
It’s available now, let me know if you see anything wrong.
Yep, works as expected!
Thanks
