I’m new before trying AudioRelay I wanted to check it meets my needs. I want to stream a physical radio connected to my PC via the mic/aux input to my phone. Most importantly I’d like the ability to automatically record shows. Also, I’d like the ability to rewind, pause and fast-forward the stream.
If AudioRelay can’t is there anything you can recommend?
