I want to make my phone receive audio and act as a mic at the same time
Im Using a Xiome 9 pro 5g
And im using a PC not a laptop
AudioRelay 1.0.0
AudioRelay 1.0.0
Please try this version.
Let me know if this works OK for you.
Hello! Im using the new version of this app on android. and there isn’t a page called Server for me. Do i need to get the premium version or not ,for it to work?
Ohh Nevermind i downloaded the other version of the App! Thanks You Helped!
Umm ,soo i connected it but i can hear myself and everyone can hear my audio thru my mic. is there any way to fix that?
If you can hear yourself, does that mean that you’ve selected VB-Cable in both the server and the player screens?
To fix this, you need to select another audio device in the server screen. In the end, the audio would flow this way:
From your PC: Other audio device → AudioRelay (over the network) → phone speakers or headphones
From your phone: Mic’s phone → AudioRelay (over the network) → VB-Cable input → VB-Cable Output → Discord (or else)
If can’t select another audio device, let me know.
