I have No sound
Hi all. Everything worked fine with version 0.12.1 on Windows 10 and Android 5. But when I updated the PC version to 0.12.4, the sound disappeared! Then I updated both versions to 0.22 - nothing changed. Thank you in advance.
Could you please check the following:
  • That you’ve tested with 0.22.1, not 0.22.0
  • Does it work if you select an input device instead of your speakers? (Your mic for example)
  • Reinstall 0.12.4 from here and turn off the EventSync option
If turning off EventSync doesn’t solve the issue, does using this virtual audio device work? (Either as input or output device)
Hello, disabling eventsync on 0.12.4 helped. Thanks very much
Thanks for testing!
I wasn’t sure if the option was useful until now. :slightly_smiling_face:
I just finished 0.12.4 installing process by clicking “Launch AudioRelay” and sound appeared before even a second passed! (Without doing anything else at all)
Windows 10 (last update), x64
Android 13.0 TecnoSpark20Pro (last update)
P.S. I’ve looked at settings and “Use EventSync” was enabled at start
P.P.S. I’ve reinstalled new version, it broke that all again, reinstalled old and all started to work again, even without reloading, changing “Use EventSync” didn’t make difference, sound continued working anyway.
I got the latest version and it doesn’t have sound how can I fix that .0.27.5
