I speak Russian but program is in English. How can I change language? I use pro version of program.
Hello Greg,
The mobile app should automatically be in Russian if your device is also set to Russian.
Make sure that you have the latest version from the Google Play Store.
In the app, go to Settings then language. Do you see Russian there?
If you’re talking about the PC version, there’s no translation available there yet.
