Failed to load audio devicesAudioRelay won't be able to stream your audio, please contact support. Include the logs in your report if possible
After installing audio relay, it worked for a little while. It automatically sent audio output to my android. Later while I tried to connect via USB, that massage started showing up"Failed to load your audio devices AudioRelay won’t be able to stream your audio, please contact support. Include the logs in your report if possible". Now it does not work any way. I tried to reinstall the app but did not work. I also install vb_audio virtual cable, vb audio is showing up in my laptops sound setting but it is not showing up in the audio relay app.
Windows 10-64bit.
I am trying to use my android as an speaker for my laptop:
Windows 10
