Extremely High CPU Usage
Hello there,
The application was working fine for many months but all of a sudden when I connect my phone (via usb tethering), the cpu usage goes through the roof as you can see from the screenshot:
It makes the computer unusable during the extreme CPU usage.
P.S: This happens when I reconnect my phone to my PC (with USB Tethering)
Versions I use: Windows 10: 0.9.1
Android 10: 0.10.1
Hey,
Sorry about that,
Please let me know whether this version fix your the issue
https://www.dropbox.com/s/7nrsrheiroj5adt/audiorelay-0.9.2.exe?dl=0
Hey there,
Thanks for the response! I tried the version you provided and the CPU usage is significantly less than the previous version.
Thank you very much and Hope you continue your development on this application.
