Error while connecting
My laptop server is being displayed on the app but whenever i try to connect an error comes "Cannot connect, the connection is temporarily down or something is blocking it
I tried with multiple connection nd also with usb tethering
Hello @Shaunak_Sawargaonkar,
In the server, please click on the check firewall button and apply the default rules there.
Then try to reconnect.
If that didn’t work, does temporarily disabling the firewall helps?
