I’m trying to install version 0.24.0 but i got this error, can anyone help?
Admin edit:
C: \Program Files (x86) AudioRelay\AudioRelay.exe
An error occurred while trying to replace the existing file:
DeleteFile failed; code 5.
Access is denied.
Could you please tell me in which situation you are:
If you open the task manager, do you see an instance AudioRelay already running?
@tarbear123 Try to close the application if it’s still running. The installer should have closed it itself though.
that worked, thanks for your help
