Whenever I launch AudioRelay, this error pops out. Just to inform you guys though, the last time I used this app, probably months ago, it worked perfectly fine to me. So I do not know what’s the problem, but I feel like it could be because of a update.
Here is the log:
2025-03-23 11:11:49:743 [INFO] Version: 0.27.5, os: Windows 10, osVersion: 10.0
2025-03-23 11:11:50:172 [INFO] Initializing locale to en
2025-03-23 11:11:50:218 [INFO] Starting IpcCoordinatorService ...
2025-03-23 11:11:50:263 [INFO] Got open ports at 59300 and 59350
2025-03-23 11:11:50:273 [INFO] Audio socket waiting on a connection...
2025-03-23 11:11:50:276 [INFO] Starting backend...
2025-03-23 11:11:50:276 [INFO] Messages socket waiting on a connection...
2025-03-23 11:11:50:280 [INFO] Waiting for devices from windows' backend...
2025-03-23 11:11:50:281 [INFO] Starting the server...
2025-03-23 11:11:50:294 [INFO] Waiting for devices from RtAudio…
2025-03-23 11:11:50:444 [INFO] Checking for update...
[SKIKO] warn: Fallback to next API: Failed to choose DirectX12 adapter.
2025-03-23 11:11:50:781 [INFO] Wait for backend backend...
2025-03-23 11:11:50:843 [INFO] Found no update
[SKIKO] warn: Can't wrap nullptr
Failed to create Skia OpenGL context!
[SKIKO] warn: Exception in draw scope: Cannot init graphic context
2025-03-23 11:11:50:920 [INFO] Showing main window...
2025-03-23 11:11:50:965 [INFO] Audio socket connected
2025-03-23 11:11:50:965 [INFO] Messages socket created
2025-03-23 11:11:50:976 [INFO] Rendering api: OPENGL
2025-03-23 11:11:51.345 [INF] Connection ready
2025-03-23 11:11:51:418 [INFO] Backend is ready
2025-03-23 11:11:51:424 [INFO] Requesting startup settings...
2025-03-23 11:11:51.447 [INF] Handling windows startup request...
2025-03-23 11:11:51.451 [INF] Changing process audiorelay-backend priority from Normal to Normal
2025-03-23 11:11:51.455 [INF] Changing process java priority from Normal to Normal
2025-03-23 11:11:51:713 [INFO] Windows' backend devices: [WindowsAudioDevice(id={0.0.1.00000000}.{e067dd14-7be6-428d-a2f0-1b034c169b41}, type=Capture, name=Microphone (REDRAGON Live Webcam Audio), isDefault=false, sampleRate=48000, channels=1), WindowsAudioDevice(id={0.0.0.00000000}.{302a7f78-8cbd-4856-99e7-4214e2952133}, type=Render, name=Speakers (spacedesk virtual Speaker), isDefault=true, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.1.00000000}.{b778e189-0196-4fc4-a6bf-de68c4613b86}, type=Capture, name=Virtual Mic (Virtual Mic for AudioRelay), isDefault=false, sampleRate=48000, channels=2)]
2025-03-23 11:11:53:569 [INFO] Network addresses: NetworkInfo(broadcastAddresses=[192.168.1.255], localAddresses=[192.168.1.2])
2025-03-23 11:11:54:223 [INFO] Virtual mic: not installed, Virtual speaker: not installed
