Doesn't work when PC is connected to VPN
Title pretty much.
The server shows the IPs but doesn’t show in client. Can’t connect manually either. Tried using ForceBindIP, but might’ve been on wrong track with that.
According to your other post, you’re using Wireguard.
Have you already tried to change the AllowedIPs property?
You set it to the IPs that you want to route through the VPN.
So in your case, you’d probably want to route all possible “internet” IPs and ignore the LAN ones.
If it’s set to
AllowedIPs = 0.0.0.0/0
change it to
AllowedIPs = 0.0.0.0/5, 8.0.0.0/7, 11.0.0.0/8, 12.0.0.0/6, 16.0.0.0/4, 32.0.0.0/3, 64.0.0.0/2, 128.0.0.0/3, 160.0.0.0/5, 168.0.0.0/6, 172.0.0.0/12, 172.32.0.0/11, 172.64.0.0/10, 172.128.0.0/9, 173.0.0.0/8, 174.0.0.0/7, 176.0.0.0/4, 192.0.0.0/9, 192.128.0.0/11, 192.160.0.0/13, 192.169.0.0/16, 192.170.0.0/15, 192.172.0.0/14, 192.176.0.0/12, 192.192.0.0/10, 193.0.0.0/8, 194.0.0.0/7, 196.0.0.0/6, 200.0.0.0/5, 208.0.0.0/4
Reddit post about that
Source on how to get the IP ranges
Worked like a charm! Thank you!
