When I switch my power config to Low, which implies low CPU performance, as long as I try to connect my Andriod to my Windows within one wifi, a socket error will show up contantly for a dozen of times before AudioRelay finally establishes the connection. During this peroid, CPU occupation soars to 100% and the sound is reduced to broken pieces or silence at its worst. I’m curious about this mysterious phenomenon.
Sorry for a belated reply. Since I was using version 0.9.1 then, my problem may be the same as another post that says his CPU usage is high, and that could be the reason. Anyway, it doesn’t bother much, and seems fixed in the new version.
