2023-03-23 20:10:08:840 [INFO] Version: 0.27.3, os: Windows 10, osVersion: 10.0
2023-03-23 20:10:14:047 [INFO] Initializing locale to es
2023-03-23 20:10:15:103 [INFO] Starting IpcCoordinatorService ...
2023-03-23 20:10:16:197 [INFO] Got open ports at 59300 and 59350
2023-03-23 20:10:16:398 [INFO] Messages socket waiting on a connection...
2023-03-23 20:10:16:399 [INFO] Audio socket waiting on a connection...
2023-03-23 20:10:16:575 [INFO] Starting backend...
2023-03-23 20:10:16:843 [INFO] Starting the server...
2023-03-23 20:10:16:844 [INFO] Waiting for devices from windows' backend...
2023-03-23 20:10:17:027 [INFO] Waiting for devices from RtAudio…
2023-03-23 20:10:17:064 [INFO] Wait for backend backend...
RtApiWasapi::probeDeviceInfo: Unable to retrieve device mix format.
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_UNCAUGHT_CXX_EXCEPTION (0xe06d7363) at pc=0x00007ffacdd54f69, pid=5216, tid=1232
# JRE version: OpenJDK Runtime Environment Temurin-17.0.2+8 (17.0.2+8) (build 17.0.2+8)
# Java VM: OpenJDK 64-Bit Server VM Temurin-17.0.2+8 (17.0.2+8, mixed mode, tiered, compressed oops, compressed class ptrs, g1 gc, windows-amd64)
# Problematic frame:
# C [KERNELBASE.dll+0x34f69]
# No core dump will be written. Minidumps are not enabled by default on client versions of Windows
# An error report file with more information is saved as:
# c:\Program Files (x86)\AudioRelay\hs_err_pid5216.log
# If you would like to submit a bug report, please visit:
# https://github.com/adoptium/adoptium-support/issues
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
# EXCEPTION_UNCAUGHT_CXX_EXCEPTION (0xe06d7363) at pc=0x00007ffcb40a4f69, pid=3924, tid=476
# C:\Users\luca\desktop\audiorelay-crash.log
I actually had same issue on my new Dell Inspiron 15.
It crashed with Error: Child process exited code 1
Tried everything with graphic card… but then checked log and was same as this post.
New version you posted helped and works fine.
Thank you.
Best regards
Jakub
