Crash on startup - Assistive Technology not found
Ever since the update to 0.25.5, AudioRelay crashes on startup with the following error.
app_version: 0.25.5
os: Windows 10
os_version: 10.0
thread: main
java.awt.AWTError: Assistive Technology not found: com.sun.java.accessibility.AccessBridge
	at java.desktop/java.awt.Toolkit.newAWTError(Unknown Source)
	at java.desktop/java.awt.Toolkit.fallbackToLoadClassForAT(Unknown Source)
	at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(Unknown Source)
	at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
	at java.base/java.util.HashMap$KeySpliterator.forEachRemaining(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
	at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(Unknown Source)
	at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
	at java.base/java.util.stream.ReferencePipeline.forEach(Unknown Source)
	at java.desktop/java.awt.Toolkit.loadAssistiveTechnologies(Unknown Source)
	at java.desktop/java.awt.Toolkit.getDefaultToolkit(Unknown Source)
	at java.desktop/java.awt.Toolkit.getEventQueue(Unknown Source)
	at java.desktop/java.awt.EventQueue.invokeLater(Unknown Source)
	at java.desktop/javax.swing.SwingUtilities.invokeLater(Unknown Source)
	at yS0.a(SourceFile:1)
	at fp.a(SourceFile:13)
	at EK.a(SourceFile:253)
	at Yu.a(SourceFile:11)
	at bg.b(SourceFile:5)
	at hp.run(SourceFile:163)
	at kt.r(SourceFile:582)
	at ID€.y(SourceFile:5)
	at EK.a(SourceFile:15)
	at com.azefsw.audioconnect.desktop.app.MainKt.main(SourceFile:112)
Caused by: java.lang.ClassNotFoundException: com.sun.java.accessibility.AccessBridge
	at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(Unknown Source)
	at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(Unknown Source)
	at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
	at java.base/java.lang.Class.forName0(Native Method)
	at java.base/java.lang.Class.forName(Unknown Source)
	... 25 more
Last known good version is 0.24.7.
PC:
Custom built, Windows 10
CPU: Ryzen 5 3600
GPU: Radeon RX Vega 56
AudioRelay 0.25.5
EDIT:
It’s fixed in 0.27.
Download it from
If any dev has the same issue, simply add the jdk.accessibility module to your jlink command.
OLD RESPONSE:
Hmm, have you installed an accessibility software (or any screen reading app) on your PC?
I saw some suggestions to either:
Second suggestion seems to have done the trick, thanks!
